Home » Audio » Pro Sound » Folded horns - W verses equiangular spiral
Re: Folded horns - W verses equiangular spiral [message #28020 is a reply to message #28019] Tue, 11 January 2005 09:38 Go to previous messageGo to previous message
>>I've noticed on several forums lately that a new popular opinion is forming. The "W" fold was probably the most popular basshorn shape since the early days of the Klipschorn in the 1940's. But lately, I see more and more references to them being worse than direct radiators.
That's bull, a folded horn will always out perform a direct radiator as far as lower distortion and more SPL's go. They just won't go as low in freq as a direct radiator can with out becoming massive. And there's tests out there that will prove it.
>>can you see any reason why a spiral fold basshorn would outperform a "W" fold?
Possibly depends on what the x-over freq is. A "W" fold it seems to me can throw out more mb gack if you want to call it that, than what a spiral horn would because of the harmonics and the way the horn path is laid out. A spiral horn has more turns to go through so some of that gack gets attenuated going around more corners.
>>If the path length is the same and the area expansion is the same, it sems to me that performance would be the same at low frequencies.
It should be.
>>I would think the main deal is packaging and layout if all other things are equal.
That's true.
>>Could the preference be a new misconception?
Sounds like somebody's trying to yank-yer-chain.
Just my thoughts on the subject.
Bill W.
Previous Topic: Over Dwell the reverb surf pan
Next Topic: Presence control for my guitar
Current Time: Sun Nov 29 00:51:46 CST 2026
