Home » Audio » Pro Sound » High output basshorn
High output basshorn [message #27975] Tue, 02 November 2004 11:38 Go to previous message
As many of you know, I am investigating options for a high-output, low-distortion basshorn. Since choices for low-distortion woofers with shorting rings are somewhat limited, I'm thinking of using a pair of 12" drivers in a push-pull arrangement to reduce distortion. The LAB12 is probably a good choice, mounted in a push-pull arrangement. I am also considering a larger version with high-power 15" drivers. Probably use a pair of drivers like the 1000 watt Beyma 15P1000 or Eminence Kilomax 15. It would be larger and have a slightly higher cutoff point, but would provide greater average SPL. What do you think? I'm thinking of doing some modeling and see where it takes me.
Previous Topic: solid state guitar amp ....... wanna make a kzillion$ ?
Next Topic: Bass cabinet design
Current Time: Mon Nov 02 11:08:03 CST 2026
