Home » Audio » Pro Sound » Bill Fitzmaurice - Questions
Bill Fitzmaurice - Questions [message #27964] Mon, 20 September 2004 15:31 Go to previous message
Ralph is currently offline  Ralph
Thanks for sending measurements for the DR200.
I have a few questions.
1. What is the port frequency? There was more output below 125Hz so I assume it was 60Hz or thereabouts?
2. How do you decide what frequency to port? Is it mathematical using T/S parameters or is it empirical cut and try? If mathematical, how do you determine how much parameter offset from horn interaction? What I mean is the T/S specs will shift and Fs will drop when installed in the horn, so shouldn't calculations use the shifted T/S values?
3. What measurement system do you use? What software do you use to make your response charts?
Thanks,
Ralph
Previous Topic: Bass speakers
Next Topic: Drew Daniels website
Current Time: Sat Nov 28 17:36:43 CST 2026
