Home » Audio » Pro Sound » Sample rate conversions
Sample rate conversions [message #27834] Fri, 15 August 2008 13:33 Go to previous message
karle is currently offline  karle
I will be doing some tests, to find out if people can really hear the
difference if a song is played at different sampling rates.
Does anyone knows about a computer / Software / Hardware bundle that would
enable playing songs and changing the master clock on the fly? I would need
the DA converter to switch its clock automatically, according to the signal
it receives at the inputs and the finest equipment if possible.
Also, if you already conducted such an experiment, I'd like to know:
should I:
1-Start with a 192khz source, downsample it and play it back at the
downsampled rates on the D to A converter
2-Start with a 192khz source, downsample it and play it back at the highest
rate on the D to A converter
3-Record the same performance at different sample rates and then play it
back at its native sample rate
Karle
Previous Topic: alternative to '59 bassman
Next Topic: Can Someone Tell Me What This Is?
Current Time: Tue Oct 27 20:24:00 CDT 2026
