Home » Audio » Pro Sound » amps and extension cabs
amps and extension cabs [message #27648] Fri, 06 February 2009 14:23 Go to previous message
Stuart John Lawrence is currently offline  Stuart John Lawrence
Hi can you help?
I have a Marshall 18W 1974 with a 16ohm spkr-but there is a swith for 4-8 - and 16 ohms
I want to run my extn cab rated at 8 ohms with it - what do i set the switch to? thanks Stuart
same question for a vibrolux running two 8 ohmd spkrs so 4 ohms amp says not to run below 2 ohms -can i use the 8 ohm extn and the built in spkrs at the same time ?
Previous Topic: Fender Performer 1000 problem
Next Topic: 4-10 bass cab inductor
Current Time: Wed Oct 21 18:06:29 CDT 2026
