Home » Audio » Pro Sound » Removal of Transformer From Old Jensen Speaker
Re: Removal of Transformer From Old Jensen Speaker [message #27611 is a reply to message #27610] Thu, 28 August 2008 16:00 Go to previous message
Sounds like you have a speaker with a field coil instead of a fixed magnet. Does it have four wires coming from it? If so, it is most likely a field coil speaker. You'll need a power supply for it because one pair of wires is the field coil, which is an electromagnet. This is used in place of a fixed magnet. The voice coil works just like speakers with a fixed magnet, signal current is applied through it and this causes the cone to move.
Previous Topic: finding a better amp
Next Topic: ??????Can any of you tech's help?????
Current Time: Thu Oct 01 23:13:36 CDT 2026
