Home » Audio » Pro Sound » Vox Amp Issue
Re: Vox Amp Issue [message #27603 is a reply to message #27602] Tue, 29 July 2008 12:10 Go to previous message
An easy test is to substitute and known good part and see if the symptoms change. The input tube is inexpensive enough I think it makes sense to buy one. Even if that's not what's bad, you can always use a spare tube.
Another thing that might be worth buying is a tube tester. You can find them on eBay.
Previous Topic: different amp heads and cabinets
Next Topic: alternative to '59 bassman
Current Time: Tue Oct 27 20:24:13 CDT 2026
