Home » Audio » Pro Sound » Fender Bass amp sound fading out
Re: Fender Bass amp sound fading out [message #27378 is a reply to message #27334] Sat, 30 December 2006 16:29 Go to previous message
CELT is currently offline  CELT
More than likely bad power supply caps. Modern Fender amps seem to have a higher than normal capacitor failure rate. Another thing to check are the plastic input jacks. If the metal retainer ring has fallen out, the plug will move around and make/break contact.
Previous Topic: Crown XTi Amps and JBL Speakers - Do I need an additional crossover?
Next Topic: 3BX III Transistion Level Potentiometer
Current Time: Tue Oct 20 13:30:09 CDT 2026
