Home » Audio » Pro Sound » Amp cuts in and out
Re: Amp cuts in and out [message #27370 is a reply to message #27369] Fri, 22 December 2006 10:24 Go to previous messageGo to previous message
Clean the tube contacts, mechanical connections and potentiometers. I would use a flux remover or tuner cleaner made specifically for electronics. Hopefully, that's all you'll need. Might check the tubes too and make sure they're all fresh.
Previous Topic: 50's Marvel 25 Amp Info Needed
Next Topic: Cleaning Old Contacts?
Current Time: Mon Nov 30 11:15:20 CST 2026
