Home » Audio » Pro Sound » Carvin V3 vs Hughes and Kettner Switchblade
Re: Carvin V3 vs Hughes and Kettner Switchblade [message #27343 is a reply to message #27331] Mon, 25 September 2006 05:02 Go to previous messageGo to previous message
Biggizmo54 is currently offline  Biggizmo54
The choice would depend on the sound you desire. When purchasing an amplifier, the most common mistake is to use a shop axe. Use the one you are familiar with...then try different axes from the shop to voice versatility in the amp itself...spend time with it. Either amp you suggested are excellent. You gotta play it like it is supposed to be played. Take note of effects response and vibration at various level in bottom. What is that speaker cone telling you?
Previous Topic: help me out. amps for gigging
Next Topic: Question regarding speaker cables
Current Time: Sun Nov 01 06:27:22 CST 2026
