Home » Audio » Pro Sound » JCM800 50W 4210 developed crackling problem
Re: JCM800 50W 4210 developed crackling problem [message #27328 is a reply to message #27327] Thu, 24 August 2006 14:50 Go to previous message
Harlequin is currently offline  Harlequin
Thanks for the comprehensive answer. Hehe, and on your final point I had actually started to look at other amps, how did you know?!
I've actually found the culprit I think, one of the plates/cathodes(?) in the output valve/tube had come loose, and was floating about freely inside the glass envelope!!! Is this a common fault?
Anyway I think I'll get a new pair of output valves and get an engineer to bias it properly and to give it a pat on the head. Thanks for your help
Previous Topic: Acoustic Amp
Next Topic: help needed with vellocette
Current Time: Thu Nov 19 19:22:21 CST 2026
