Home » Audio » Pro Sound » JCM800 50W 4210 developed crackling problem
Re: JCM800 50W 4210 developed crackling problem [message #27327 is a reply to message #27326] Thu, 24 August 2006 13:24 Go to previous messageGo to previous message
Aki is currently offline  Aki
If your amp is having problems, cap job may indeed be needed, but intermittent crackles can be caused by a number of things. I've seen resistor drifted or even cracked open, solder joints cracking open, tube going noisy and coupling caps leaking DC.
So I'd take it to a good shop and have it checked out. Just for reference, the following is what I do when I add yet another tube amp to my collection.
Re-tension or replace loose tube sockets.
Look for cracked or about to be cracked solder joints. There is always a couple.
Check values of resistors and change any that have drifted.
Clean or replace pots and jacks.
Check all coupling caps for leaking DC. I usually change the output stage coupling caps anyways, as DC leak here can cause output tubes to melt down.
Check and replace power supply filter caps if needed, including bias filter caps.
Check and/or replace all small value electrolytic caps.
Finally, check all the voltages around tubes, set bias.
Plug in and rock on away.
Alternatively, sneak it into storage so Mrs. doesn't find out that you bought yet another old tube amp.
Previous Topic: Acoustic Amp
Next Topic: help needed with vellocette
Current Time: Thu Nov 05 22:52:34 CST 2026
