Home » Audio » Pro Sound » matchless chieftain transformers
Re: matchless chieftain transformers [message #27133 is a reply to message #27132] Sat, 20 August 2005 15:41 Go to previous message
Hm, 20mH seems like pretty small choke in tube amp PS, it`s more likely that it`s 10-20H choke. I don`t have PS schematic, but I suppose that`s "guitar amp classic" - B+ for output tubes is from the first cap, then Pi-filter (choke+another cap) for screen grids (g2), then RC filters for splitter/preamp tubes. I found amp schematic, and it shows about Uak~390V "through" each EL34, cathode biased - each EL34 with Rk=270 Ohms+cap. On schematic, Uk=24V. That means that current through the EL34 Ia+g2 = Uk/Rk = 24/270 = 88,9mA. And dissipation through the each tube is Pa+g2 = 390*0,0889 = 34,6W!
Much more then Pa+g2 max. for EL34.
Well, maybe I found not so good schematic on the web - can you post the link of your schematic? And schematic is not everything - layout, choice of parts make much difference.
IMO - if you have tons of experience, good schematic and known layout - go on with this project. But, if not - maybe first try some books by Kevin O`Connor. There are some with complete schematics, layout, etc. - see "London Power" site for more details.
Previous Topic: Elec guitar thru speakers vs amps (do amps make them sound 'electric'?)
Next Topic: Polypropylene Caps Panasonic vs. Sprague Orange Drops
Current Time: Thu Nov 05 04:47:01 CST 2026
