Home » Audio » Pro Sound » ohms selector to mono input
Re: ohms selector to mono input [message #27069 is a reply to message #27066] Tue, 07 June 2005 14:38 Go to previous message
Match the speaker to the amp. Set the amp according to the impedance of the speaker.
You can parallel two speakers to cut impedance in half, or put them in series to double them. This assumes speaker impedance is equal; If not calculate with the following equations:
Series:
ZT = Z1 + Z2 + Z3...
Parallel:
ZT = 1 / (1/Z1 + 1/Z2 + 1/Z3...)
Where:
ZT is total impedance
Z1 is impedance of speaker 1, Z2 is impedance of speaker 2 and so on.
If you use four speakers, all the same impedance, connect two in series and then connect each series pair in parallel. The total impedance will be the same as a single unit. So if you connect four 8Ω speakers this way, the total impedance will be 8Ω.
Previous Topic: Marshall Valvestate 65 wont turn on anymore
Next Topic: friend is building an amp... wants to use guitar and bass head inversly
Current Time: Sun Oct 18 07:38:08 CDT 2026
