Home » Audio » Pro Sound » Marshall Valvestate 65 wont turn on anymore
Re: Marshall Valvestate 65 wont turn on anymore [message #27064 is a reply to message #27062] Mon, 06 June 2005 18:46 Go to previous messageGo to previous message
Without looking at it, my money is on power supply caps. Short
of finding a loose solder joint or being able to make it happen
by tapping on things with a wooden/plastic stick, you're likely
to need a 'scope to see where the transients are coming from.
Tube use high voltage, so be very careful. Only one hand near
the chassis at a time. The other one goes in your pocket.
Chris
Previous Topic: jtm 45 problem
Next Topic: ohms selector to mono input
Current Time: Mon Sep 14 22:58:34 CDT 2026
