Home » Audio » Pro Sound » Channel jumping inputs fender to Matchless
Re: Channel jumping inputs fender to Matchless [message #27038 is a reply to message #27037] Tue, 03 May 2005 13:30 Go to previous messageGo to previous message
walters is currently offline  walters
I thought Y cord was different because its not using the other
68K resistor in the Low input mostly used on amps to daisy chain
Daisy chain uses both jacks using both 68K resistors
example- guitar goes into 68k input resistor hi input jack
The Low input jack 68K input resistor is daisy chained
to the other amps channel input so there is another
68K
So Daisy chain uses 3 input 68K resistors so the impendances
is different because there is 3 68Ks resistors in parallel
The Y cord just uses 2 input 68K resistors i don't know if its in
parallel i know the signal from the guitar is parallel to the
amp channals
example: guitar output gets Y cord the Y cord splits to Two
different different amps channels one being a marshall
and other amp being a fender amp. So there is only
2 68K resistors and not in parallel i think
So the Y cord uses 2 68k resistors
The Daisy chain uses 3 68K resistors in parallel or more if you
have more and more amps
So the impedances are way diffeerent from using a Y cord than
Dasiy chain
what do you think im guessing here
Previous Topic: Need help fixing HRDx
Next Topic: Marshall DSL50 v DSL100
Current Time: Sun Oct 18 08:20:45 CDT 2026
