Home » Audio » Pro Sound » Using a bass amp for electric guitar.
Re: Using a bass amp for electric guitar. [message #27015 is a reply to message #27006] Thu, 07 April 2005 16:36 Go to previous message
Disco Stu is currently offline  Disco Stu
I agree in fact i actually use an old randall bass amp in the studio with a 15" speaker in it. The combination of the 15" with the great sound that the head generates gives a really beefy rhythm sound for all types of music.
Id also suggest if you are going to mic a guitar cab a good method i came across is to use 2 SM57s not betas just the regular type point one directly at the speaker and EQ it with NO bottom end then take another and angle it in from the side so you get this sort of positioning | \ then EQ the angled mic with no top end. Then mix the two together. This way you get a balanced sound which is big enough to be used in mono as a rhythm part rather than having to do endless takes of the rhythm track and then panning them all which ways. This all saves tracks which in home studio cases really helps.
Stu
Previous Topic: guitar amp functioning
Next Topic: Lab Horn
Current Time: Mon Sep 14 17:28:42 CDT 2026
