Home » Audio » Pro Sound » tube amp output power question
tube amp output power question [message #26984] Wed, 19 January 2005 18:45 Go to previous message
Rich Watkins is currently offline  Rich Watkins
Mesa Boogie 20/20 stereo power amp has several output jacks on the back of the unit used for connecting you speaker cabinets. Two of the jacks (one left and one right) are labeled as 8 ohms. There are four other jacks also that are labeled as 4 ohms, (two left and two right). My question is this: I will be using a 4x12 cabinet that wired in stereo. All speakers in the cab are 8 ohms each. The left pair of speakers will be wired in parallel resulting in a 4 ohm load (for the left side). The right side speakers will be wired the same, also resulting in a 4 ohm load. Each pair of speakers with have its own 1/4 inch jack. Each speaker pair will totally independent from the other. Which set of output jacks (on the 20/20) should I use to power this stereo cabinet. I assume I should use a four ohm pair (one four ohm out left and one four ohm out right). Will the 20/20 provide equal output power to different load value cabinets? I want to get the full output potential in stereo out of this amp. Any help is appreciated.
Previous Topic: Update to DIY site
Next Topic: EAW COMMERCIAL ONLINE RETAILERS
Current Time: Sat Oct 17 11:47:29 CDT 2026
