Home » Audio » General » Flat down to 100Hz on a 224Hz baffle ?
Re: Flat down to 100Hz on a 224Hz baffle ? [message #26820 is a reply to message #26819] Fri, 10 December 2004 09:59 Go to previous messageGo to previous message
hitsware is currently offline  hitsware
Works on a 'sim', but with a ~1db hump at just above 100Hz, and a ~1db dip @~200Hz. It might start sounding like an unstuffed pipe if you push that method too far ?
Here's a question. I've been 'siming' OB's by using an infinite baffle (sealed with alpha of 0.01) and emulating the baffle as a first order HP filter (@Fc of proposed baffle).
If I added a capacitor in series with the driver (in the real world), would the resultant filter (the reactance of the capacitor + the rolloff of the baffle) combine as a second order filter or still a 1rst order but at a higher frequency? If a second order what would the damping be ? ..... ?
Previous Topic: Audio Critic
Next Topic: lots of nice new faces here.
Current Time: Mon Nov 23 00:18:01 CST 2026
