Home » Audio » General » alighnments
Re: alighnments [message #26814 is a reply to message #26813] Tue, 07 December 2004 00:16 Go to previous messageGo to previous message
That sounds like a good plan. I'm reasonably confident that the fastest and most well defined rolloff will be on a circular baffle with the driver in the center.
You might makes some test baffles with cardboard of different shapes and configurations and do some measurements to test everything out. I'd experiment with smaller baffle sizes to shift the frequency up so measurements would be easier. Maybe try 9 inches to a foot, using a small midrange driver. The higher in frequency you go, the smaller the distances involved and the easier it is to gate out reflections from walls and stuff. Once you have defined properties, you could scale up to the size you want and go with a larger driver for your 100Hz model.
Previous Topic: MARANTZ 2325
Next Topic: Audio Critic
Current Time: Fri Oct 16 20:19:42 CDT 2026
