Home » Audio » General » alighnments
Re: alighnments [message #26813 is a reply to message #26812] Mon, 06 December 2004 18:16 Go to previous messageGo to previous message
hitsware is currently offline  hitsware
>Instead of an abrupt rolloff, you'll
>probably have more energy below 100Hz
>than if the baffle were a 3' circle.
Yea ..... But .....
Here's my (tentative) plan:
Use a widerange driver to get down to say 100Hz.
So a 100Hz driver with a Q of 1 will give a flat
response (Q=~.7) on a 100Hz baffle.
Then add a 'helper woofer' to extend down an octave.
(rolled off on the high end with a 12db/octave passive
network)
(a driver with a Q of 2 @ 50Hz on a 100Hz baffle is
flat down to 50Hz)
Thus the need for a fairly good definition of baffle
cutoff since the baffle is used as a crossover element.
Previous Topic: MARANTZ 2325
Next Topic: Audio Critic
Current Time: Sun Nov 22 23:49:43 CST 2026
