Home » Audio » General » alighnments
Re: alighnments [message #26808 is a reply to message #26807] Sun, 05 December 2004 22:28 Go to previous messageGo to previous message
If the baffle is circular with the radiator in the center, then the distance from the sound source to the edge of the baffle is the same in all directions. That will make the transition from 4π to 2π happen over a narrow range because the distance to the edge is the same in all directions.
But if the baffle isn't circular with the driver in the center, transition is staggered and more gradual. Defining an effective diameter for any baffle shape other than circular is a simplification. If you consider the shortest dimension then you'll probably have a little more bass energy than you expect and if you average area, you'll probably have a little less.
Previous Topic: MARANTZ 2325
Next Topic: Audio Critic
Current Time: Fri Oct 16 20:19:20 CDT 2026
