Home » Audio » General » Jensen RP103 Orientation
Re: Jensen RP103 Orientation [message #26739 is a reply to message #26738] Thu, 15 January 2009 23:44 Go to previous messageGo to previous message
If you can see or feel the diaphragm, you can possibly tell what direction it is moving when a small voltage is applied. You can connect a 1.5v battery across the terminals and see what direction the diaphragm moves. This is simple on cone or dome tweeters, but not so easy on compression drivers and horns. In that case, you need acoustic measurement equipment.
Previous Topic: HELP....What ohm are these Utah speakers?
Next Topic: Western Electric output transformers
Current Time: Thu Nov 05 08:12:05 CST 2026
