Home » Audio » General » AIWA CX-NMT240
Re: AIWA CX-NMT240 [message #26641 is a reply to message #26640] Tue, 28 August 2007 08:57 Go to previous messageGo to previous message
You can't disable the power saving feature? Try cycling the power. That may allow you to reprogram the unit. Otherwise, if you're doing what the manual says, it may be broken. I had a car stereo like that once - You couldn't set the clock. All other features worked but it wouldn't enter the clock setting mode. The only way to do it was to wait until noon or midnight and remove power at that time.
Previous Topic: Hello from Reno Nevada!
Next Topic: will you go to a Pavarotti?
Current Time: Sun Oct 04 19:18:52 CDT 2026
