Home » Audio » General » Eico HF85... "persistent hum"
Re: Eico HF85... "persistent hum" [message #26628 is a reply to message #26624] Mon, 25 June 2007 17:18 Go to previous messageGo to previous message
Disconnect the output from the HF85. Is the hum still there? If so, it's the amp, not the preamp.
Now disconnect the input to the HF85. Is the hum still there? If so, then it may be power supply hum or something else internal to the HF85. If not, it's the source. Check your ground, cables and source equipment.
Grounding problems are very common, so make sure your ground is good.
Previous Topic: Happy 4th of July!
Next Topic: Congratulations, Tulsa
Current Time: Thu Oct 29 07:26:23 CDT 2026
