Home » Audio » Radio » Replacing Selenium
Re: Replacing Selenium [message #26078 is a reply to message #26077] Mon, 16 March 2009 13:37 Go to previous messageGo to previous message
The forward voltage drop across a selenium rectifier plate is approximately 0.5v - 1.0v, so you could count the plates to estimate the drop produced by the stack.
I have selenium stack in my TransOceanic radios. I'll power one of them up and measure across it. As I recall, the voltage drop was not huge - like a few volts, maybe 10. It would be similar to a series string of germanium or silicon diodes, each having 0.3v to 0.7v across it, each adding to the total voltage drop.
You could mimic this behavior with a series string of more modern semiconductor rectifiers or a diode and resistor. If the circuit is low voltage, like a filament circuit, I might be inclined to do that. But if it's the B+ supply, I think that the DC voltage desired is probably high enough that a few volts loss isn't required for proper operation. In that case, I think you probably could replace it with a single diode having less than a volt drop across it.
Previous Topic: Abbotwares Prancing Horse
Next Topic: Wards Airline 62-1057 help?
Current Time: Mon Nov 16 07:59:25 CST 2026
