Home » Audio » Radio » Montgomery ward WG&C Series 8A56
Re: Montgomery ward WG&C Series 8A56 [message #26026 is a reply to message #26025] Mon, 19 May 2008 11:33 Go to previous message
That is a common symptom of old tube gear. Many times, the capacitors are bad but everything else works fine, even the tubes. If you can swap the power supply capacitors, try that first and see if that fixes it. If you can't solder or identify the capacitors, take it to someone who can. It isn't a difficult job and the parts don't cost much. There's a good chance that will fix it.
Previous Topic: Wards Airline Radio Phono Combination YR?
Next Topic: AudioQuest Type 4+ Wire
Current Time: Mon Nov 09 07:59:49 CST 2026
