Home » Audio » Radio » Zenith 9-S-262
Re: Zenith 9-S-262 [message #25912 is a reply to message #25897] Sat, 30 December 2006 11:21 Go to previous messageGo to previous message
Do you have an oscilloscope? If so, check the IF oscillator and alignment of the IF stages. I've had a couple radios with bad IF coils and the symptoms are exactly the same as you've described. All tubes good, all caps good, just a hum in the output. Without an IF oscillator, there's no way for the signal to get through the IF stages. So check the trimmers on the IF coils, make sure they're aligned, and make sure the IF oscillator is singin'.
Previous Topic: ward aline radios
Next Topic: airline radio
Current Time: Fri Nov 06 03:21:43 CST 2026
