Home » Audio » Radio » Crystal Sets.
Re: Crystal Sets. [message #25877 is a reply to message #25876] Sun, 06 August 2006 23:36 Go to previous messageGo to previous message
Yes, but I cheated and used germanium diodes instead of a real galena "crystal" and safety pin ("cat's whisker"). Check out the galena crystal and cat's whisker "Philmore Mounted Crystal Detector Stands" on this page:
http://home.earthlink.net/%7Ewb5rex/xtalman/detectors.html
Another thing to use for a detector was an old fashioned double edge razor blade, in particular, the (Gilette?) "blue blade". Touching the tip of the safety pin (or pencil lead) to the blue area, right next to the silver area would supposedly act as a detector. Those old blades no longer exist.
http://www.geocities.com/safetyrazors/blades/DEBladePage.htm
Makes you wonder who first got the idea... "Hey, let's take a razor blade and a pencil lead and..."
You think I jest?
http://bizarrelabs.com/foxhole6.htm (as a kid I had the book on this page "All About Radio and Television")
http://www.bizarrelabs.com/foxhole8.htm
And you had to have an oatmeal box to wind your coil... hah!
Here's the classic Quaker Oats crystal radio.
This site has lots of links, kits, plans, etc:
http://www.midnightscience.com/
http://www.midnightscience.com/catalog5.html
You can literally build this loop antenna, add an earplug and diode across the variable capacitor connections, and make a crystal radio from it:
http://www.mtmscientific.com/loop.html
Here is the correct diode, a 1N34A. You used to be able to buy a bag of these at Radio Shack for a buck or so.
http://www.mtmscientific.com/diodes.html
Just google "crystal radio" and you can find plenty of sites.
This one, Dave Schmarder's site, has both AM loop antennas and crystal radios:
http://www.schmarder.com/radios/misc-stuff/loops.htm
http://www.schmarder.com/radios/crystal/30.htm
Dave's crystal radios are very sophisticated. In fact, they are the most sophisticated crystal sets I have ever seen. Amazing!
http://www.schmarder.com/radios/index.htm
Previous Topic: Re: ID Old radio chassis? RCA?
Next Topic: Need a manual? Try hre!
Current Time: Thu Nov 26 18:04:04 CST 2026
