Home » Audio » Radio » Trancel TR 80 Transistor...might work?
Re: Trancel TR 80 Transistor...might work? [message #25749 is a reply to message #25748] Thu, 08 September 2005 06:10 Go to previous messageGo to previous message
Those are IF transformers. When you adjusted them, you moved a ferrite slug and shifted the resonant frequency. They all need to be set the same. If you're lucky, you'll be able to tune in a strong station and then adjust each of them for strongest signal. Otherwise, you'll need a signal generator and a scope.
Cool little radio, by the way. Good luck with it!
Previous Topic: Andrea 1E8 or 10E8 data needed
Next Topic: Bendix Radio Schematic
Current Time: Thu Nov 05 06:12:20 CST 2026
