Home » Audio » Radio » 300 ohm vs 75 ohm
Re: 300 ohm vs 75 ohm [message #25563 is a reply to message #25562] Fri, 13 August 2004 14:02 Go to previous message
One thing to consider is the possibility of a ground loop when a television connected to cable TV is connected to your sound system. This can also happen if you connect cable into your Hi-Fi tuner. Using a 300 ohm transformer will isolate cable ground from your sound system's ground. Many times earth ground on the house current circuit is nowhere near cable ground so if they aren't isolated, a ground loop exists. You can reduce hum considerably by isolating these.
Previous Topic: crosley tube radio. pls help.
Next Topic: Loose cap on top of tubes
Current Time: Tue Oct 27 18:23:51 CDT 2026
