Home » Audio » General » influence of interior
Re: influence of interior [message #25340 is a reply to message #25339] Fri, 03 September 2004 13:10 Go to previous messageGo to previous message
Actually the Fb will go down when you put the box into a car. The effect is similar to a dual chambered alignment, with the volume of the car interior being the second chamber, but the effect is dwarfed by cabin gain to the extent that it is rendered moot. Standing waves and room gain aren't the same, and you don't get both simultaneously, as one requires less than 1/2 wavelength room dimensions while the other requires at least 1/2 wavelength dimensions.
Previous Topic: Solder
Next Topic: Nice place!
Current Time: Fri Oct 16 22:15:19 CDT 2026
