Home » Audio » General » Subs
Re: Subs [message #25321 is a reply to message #25320] Mon, 09 August 2004 10:15 Go to previous message
If you use the trunk as the box then you can't tune the enclosure for the best possible response. You also can't just toss any old driver into a trunk mount or again it won't work (I assume that by trunk mounting you mean mounting the driver through the rear package shelf; all driver require some sort of baffle top separate the front and rear driver waves). The best bet is a tuned enclosure mounted in the trunk, or a more exotic kick panel arrangement, just as long as the enclosure and driver are properly matched.
Previous Topic: sharing info
Next Topic: Cone versus compression driver midrange
Current Time: Fri Oct 23 08:18:58 CDT 2026
