Home » Audio » Measurement » I' m too cheap
Re: I' m too cheap [message #25226 is a reply to message #25225] Mon, 21 August 2006 17:02 Go to previous messageGo to previous message
Leland is talking about using piezoelectric tweeters. The way he's using them is to listen for HF created by the leading and trailing edge of a clipped signal. If you put a low frequency sine wave into an amplifier, the output signal will also be a low frequency sine wave that can't be heard from a piezo tweeter. But once the amp starts to clip, the sharp edges generated are high frequency so they can be heard with a piezo. That's how Leland plans to use piezos to tell when his amps begin to clip.
Previous Topic: ARTA looks very good
Next Topic: converting active crossover values to passive
Current Time: Fri Nov 06 02:40:29 CST 2026
