Home » Audio » Measurement » I' m too cheap
I' m too cheap [message #25217] Tue, 13 December 2005 05:33 Go to previous message
Leland Crooks is currently offline  Leland Crooks
to buy a clipcop or a rane gain, I'm going to use my PC for a 440 sine wave into the PA. If you're not familiar with them, they generate a 440hz tone and you plug a pizeo into the output. Turn up gain until it distorts, voila, max gain. They put out at 0dbu, which I understand is 1.23v pro level. Through the di box I don't think my pc will give that much gain. I do now have a meter with a db scale. What's the formula say, if I can give -10db signal, that I can use to mathematically find the 0db level. Then I can adjust my trim knobs and turn down accordingly
I figure I'll only need to do this once, which is why I don't really want to buy one.
Previous Topic: ARTA looks very good
Next Topic: converting active crossover values to passive
Current Time: Fri Nov 06 02:38:52 CST 2026
