Home » Audio » Measurement » Using in room tests?
Re: Using in room tests? [message #25202 is a reply to message #25201] Sun, 08 May 2005 14:59 Go to previous message
If you're concerned with response above the gated frequency, then pseudo-anechoic via gating will suffice. But below the gated frequency, you're getting reflections and room resonances just like with an ungated measurement.
Previous Topic: measuring ability for amatuers
Next Topic: How Do You Use Speaker Workshop?
Current Time: Tue Nov 03 10:42:40 CST 2026
