Home » Audio » Measurement » Microphone mods
RS SPL Meter Modifications (Wallin) [message #25189 is a reply to message #25168] Fri, 14 January 2005 21:59 Go to previous messageGo to previous message
Hi manualblock
I've done all Eric Wallin's mods to my RS meter. Basically that includes replacing all of the electronic components, and using the panasonic WM-60AY mic mounted on the end of a microphone boom (piece of rod homemade). I use this setup with the Speakerworkshop program, and I have always gotten consistant results from this combination. I think it works very well and is a great and cheap way for a DIYer to make meausrements. I think RS has stopped selling this meter though, but you could just build a little preamp such as the one Wayne posted a link to instead. If you have an RS meter, the RS meter works as the preamp and is more sensitive/higher gain when you select a lower decible band, so you won't need to build a seperate pre-amp.
Adrian
Previous Topic: Thiele / Small Measurements
Next Topic: Hey Wayne
Current Time: Tue Nov 03 08:17:05 CST 2026
