Home » Audio » Room Acoustics » Speaker placement
Re: Speaker placement [message #25067 is a reply to message #25066] Sun, 10 December 2006 10:53 Go to previous messageGo to previous message
That's an interesting concept. You'll need to have speakers that are highly directional, so you'll have to try it with narrow flare horns. You may need to build something for your experiment, because most speakers have wider directivity. Some prosound gear has narrow directivity, particularly speakers designed to be used in line arrays. But even those tend to lose directional control at low frequencies, depending on array geometry to provide control down low.
Previous Topic: rigid foam
Next Topic: Subwoofer
Current Time: Thu Nov 12 04:11:59 CST 2026
