Home » Audio » Room Acoustics » rigid foam
Re: rigid foam [message #25062 is a reply to message #25060] Tue, 28 March 2006 10:29 Go to previous messageGo to previous message
nodiak is currently offline  nodiak
Hi Wayne, my friend will give me all I need, which is lucky if it works. I can cut 2 pieces and try them in corners. For measuring all I have is an octave analyzer (old Audio Control D-11), I have to change out preamps to hook it up, will try to find time today or tomorrow. Will do before and after. Is there another measuring tool that is fairly cheap? (Of course just listening to any change is key.)
I will also weigh the rigid board to find lbs/ft3 as that seems to matter?
Don
Previous Topic: Computer Simulation of Room Acoustics
Next Topic: Speaker placement
Current Time: Fri Nov 13 08:31:40 CST 2026
