Home » Audio » Room Acoustics » SPL meter confusion (long)
Re: DIY Microphone Boom [message #25010 is a reply to message #24992] Thu, 01 July 2004 12:28 Go to previous messageGo to previous message
martinleewin is currently offline  martinleewin
Adrian & Wayne,
I checked the Panasonic web site for this product line. They are discontinuing all of the wideband omnidirectional models! I will see if DigiKey still has stock.
All electret condenser mics I have seen require a phantom DC supply. The apps note schematic,
http://www.panasonic.com/industrial/components/pdf/em16_microphone%20schematic_dne.pdf, does show a 2VDC supply and load resistor needing to be hooked up.
Is this the arrangement you use? Not a major thing, but I would need to build or buy a phantom power unit since my preamp does not supply any. It does make it more than a $2 item by then.
Just wondering if the equipment you use has phantom power that is compatible? Especially since many phantom power mic inputs exceed the 10V max for this device.
Martin W.
Previous Topic: Room gain AKA cabin gain
Next Topic: Room Acoustics
Current Time: Tue Nov 03 07:52:35 CST 2026
