Home » Audio » Speaker » Acoustat 1+1 bias voltage idea
Re: Acoustat 1+1 bias voltage idea [message #24740 is a reply to message #24739] Tue, 04 October 2005 15:30 Go to previous messageGo to previous message
moray james is currently offline  moray james
Morricab: that would be great if you can borrow a supply and so some comparitive tests. You are probably right in your suspecting the is afaulty cap in your Acoustat supply.
Have a look at the Izzy Wizzy mods at this site http://www.izzy-wizzy.com/audio/spkr.html. More voltage will help but your limiting factor will be the condition of your PVC dielectric, same gors for a little extra current on the diaphram. The choke mod is a very good one and worth the twenty or so dollars it will cost you. Emco have switching supplies in the $60-80.00 range and you can have a look at this address http://www.emcohighvoltage.com/emcoindex.htm. Also (and you may have a hard time with this) you should try listening to your supplies with some top quality power cords as they too have a significant impact. I am biased toward the ones that I design but I am sure that a local high end shop can loan you a pair to try for a weekend. Please keep posting. Thanks and best regards. Moray James.
Previous Topic: RE: mounting woofer
Next Topic: Mounting Woofer
Current Time: Mon Nov 02 07:38:45 CST 2026
