Home » Audio » Speaker » Are you ready to play? Planars for peanuts,NXT!!!!!!!
Are you ready to play? Planars for peanuts,NXT!!!!!!! [message #24605] Tue, 29 June 2004 21:39 Go to previous message
Ed Schilling is currently offline  Ed Schilling
Well guys, just for starters. Check out the Sonic Impact "Sound Pads". To give you a head start......it is possible to liberate the "exciter" from the cardboard. A piece of "foam core" or stiff cardboard (!) will get you started. A sealed cardboard box is pretty good too. Check out the "Sound Pax" cardboard speakers for "inspiration". One last hint.....my M*M*G killers cost 60 bucks.........planar sound for peanuts. And if you spend enough time and money.........GOOD planar sound! Used properly the "exciters" are capable of very good sound. You'll need at least 10 watts. Have fun.
Ed
Previous Topic: has any tried tangband F SERIES W4-1337S for line array?
Next Topic: ESS HD 1200
Current Time: Mon Nov 30 11:15:34 CST 2026
