Home » Audio » Speaker » What is the min no. of 4 inchers required in an array without a sub
Re: What is the min no. of 4 inchers required in an array without a sub [message #24513 is a reply to message #24508] Sun, 02 November 2008 17:47 Go to previous message
Marlboro
If you bought dayton Neo's then you have to find a mid range that can go comfortably up to 2500 and not lose the range from 1600 to 2500. This means that you will need a three way to cover the bass. Going much above a 3.5 incher in a mid simply will cause you tolose part of the midrange.
See my version.
If you had chosen a tweeter that goes down to 1600, then you could have chosen a mid-range that would go down low enough to get some real bass with some equalization.
Marlboro
Previous Topic: Subs or no subs
Next Topic: Where would combing start with these?
Current Time: Sun Nov 22 06:00:57 CST 2026
