Home » Audio » Speaker » Wide-Range Drivers In A Line Array
Re: Wide-Range Drivers In A Line Array [message #24453 is a reply to message #24452] Wed, 18 June 2008 08:14 Go to previous messageGo to previous message
Marlboro said: "Then I added the tweeters and discovered what I was missing in the high's".
That's what I would expect too. Properly equalized for treble rolloff they wouldn't sound bad at all, but adding tweeters would restore the "air" that would be missing without them.
After I posted the initial message I recalled a PE project that mentions that same thing. The published graphs in this project are also revealing. Note the measured comb filter effect on the unsmoothed freq response graph. The builder's comments are: "Several people noted that the high-frequency reproduction lacked some "life" and "air". This could be attributed to the comb filtering problems that definitely were occuring. However, this also could be a result of the high-frequency capabilities of this particular driver, it is hard to say for sure. Whatever the reason, for pure audiophile use I would consider these lines to be slightly less "refined" and "articulate" than many standard speakers.
Too bad. I really do like the concept of a full range drive line array.
Previous Topic: Fostex 208EΣ
Next Topic: Stereo woofer array vs Stereo sub
Current Time: Thu Nov 05 21:46:55 CST 2026
