Home » Audio » Speaker » The Ultimate Array Conclusions
Forgot the obvious - CSS WR125ST (14 ohms) [message #24409 is a reply to message #24408] Tue, 20 May 2008 19:27 Go to previous messageGo to previous message
Darkmoebius is currently offline  Darkmoebius
16 ohm version of the first 4.5" speaker with patented XBL^2 motor technology and truncated for closer driver spacing.
Parameters are Fs: 65 Hz, Qms: 3.98, Qes: 0.77, Qts: 0.65, Vas: 5.8L, Sd: 57 cm^2, Xmax: 6mm one way, Re: 14.1 Ohms, Le: 0.65 mH, BL:5.7 N/A, Mms: 4.5 grams, SPL: 85.8 dB @ 1W, 1m.
Spec sheet (pdf)
Previous Topic: My ART Arrays
Next Topic: Question about magnetic flux modulation
Current Time: Tue Nov 03 09:29:23 CST 2026
