Home » Audio » Speaker » My ART Arrays
Re: Nice work... [message #24404 is a reply to message #24402] Tue, 20 May 2008 10:40 Go to previous messageGo to previous message
Mine are stable on on hardwood or thin carpets, but I don't have any small kids or pets who might push them over (my wife and the housekeeper have been cautioned to never touch the speakers). The simplest option would be to cut a couple of pieces of mdf or plywood about four inches wider and deeper than the speakers, set these bases on the carpet, then set the speakers on the bases. If you have small kids the preferred way would be to make the bases, remove the feet from the speakers, then screw the bases to the speakers from underneath.
Previous Topic: E-V model Sixteen 12" enclosure information
Next Topic: The Ultimate Array Conclusions
Current Time: Tue Nov 03 10:55:21 CST 2026
