Home » Audio » Speaker » Array kits
Re: Array kits [message #24256 is a reply to message #24255] Wed, 09 April 2008 16:21 Go to previous messageGo to previous message
The best known source for line array kits is Rick Craig of Selah Audio. The Selah RS-8 kit sells for $2,495/pr. If that's outside your budget I'm sure Rick could design a custom kit for less using planar tweeters instead of the more expensive founteks used in the RS-8. I suggest you contact him directly at the link below.
Previous Topic: BG Neo10 tests
Next Topic: Paging Marlboro - your array....
Current Time: Mon Nov 30 11:32:50 CST 2026
