Re: Everyone: What would you do? [message #24241 is a reply to message #24225] |
Thu, 27 March 2008 17:00 |
Rick Craig
Messages: 115 Registered: May 2009
Viscount |
Unless you plan to add more tweeters down the road I would use a different design format. With a single tweeter the vertical coverage is very narrow. About the only thing you achieve is high sensitivity if you have something like the Fountek CD2.0 or similar. You'll also have issues with balancing a line source pattern versus a single tweeter that operates closer to a point source.
