Home » Audio » Speaker » Is this test valid?
freq resp? [message #24130 is a reply to message #24114] Fri, 25 January 2008 06:46 Go to previous messageGo to previous message
lcholke is currently offline  lcholke
Hi Lito,
The findings are interesting. I am very curious to see how the frequency plot would look with , and without the limiter.
With the limiter between the pre amp and the power amp, you are forcing the power amp into class a mode (if it is a class b amp). This will affect your readings. Using S.W., see how the amp measures for the 2 tests. If there is no change, then the difference is in how the speaker responds with a DC bias in the signal.
-Linc
Previous Topic: Maximum efficiency? Sensitivity?
Next Topic: Boston Acoustic Speakers
Current Time: Sun Sep 13 19:03:18 CDT 2026
