Home » Audio » Speaker » Rear Folded Horn Line Array
Re: Rear Folded Horn Line Array [message #24077 is a reply to message #24073] Thu, 27 December 2007 20:10 Go to previous message
lcholke is currently offline  lcholke
Hi Jeffery,
Horns are tough. They require a lot of theory to design. The horn requires the horn length to be 1/4 the lowest wave length, so many of the designs that I have seen use a non horn for deep bass.
If you run 4 of the 10" x 24" horns, in a corner, the mouth cutoff will be 61 hz. An 8 ft 1/4 wave path has a 35 hz cutoff. (by the std equations)
http://www.dmcbean.bigblog.com.au - will provide hours of design fun http://www.audioroundtable.com/emoticons/winkie.gif
-Linc
Previous Topic: Biflex drivers
Next Topic: Line ARRAY
Current Time: Sun Nov 08 17:47:45 CST 2026
